aarchishjindal
I have a Asus Tuf F15 Intel laptop.
My current RAM is DDR5 running at 4800MT/s which is the base level speed for DDR5 and according to RAM model and spec, the RAM itself is also 4800MT/s.
I’m planning to upgrade my RAM from 16 GB (2x8) to 32 GB (2x16) Dual Channel and I would like to getter better speeds as well if possible and if they make any performance difference.
I checked the laptop BIOS and I don’t have option to overclock or enable XMP.
I’m not sure if it is enabled by default and higher speed capable RAMs will work on full speed.
