Display Sensor values from Aquacomputer Farbwerk
Thorogrim
Hello together,
i have the problem that HWInfo64 doesn´t display the values from my 2 temperatur sensors which are connected via Aquacomputer Farbwerk to my mainboard. The Aquasuite Software can read the temperatures and my windows 10 detects Farbwerk as an USb device. Is it possible to add them manually, or do i have to configure something?
I hope you can help me.
Kind regards
Thorogrim
I'm not sure if this device is supported by HWiNFO. What kind of sensors is that ?
Please attach a HWiNFO Debug File (with sensor data) and I'll check it.
so i did send it with normal e-mail, because no matter what i try, i cant attach the file. the thread remains empty....
i have the same problem that HWInfo64 doesn´t display the values from my 2 temperatur sensors which are connected via Aquacomputer Farbwerk to my mainboard.
