HWINFO using PIN instead of POUT for the VRM Vcore Power (POUT)
DangerDave
I have noticed that HWINFO64 was reporting values above the Power limit set in BIOS for Z790 Apex Encore, under the ASUS EC heading, for field VRM VCORE Power (POUT). When I open up the ASUS tool.exe (internal ASUS OC tool, that they released on the forums for enthusiasts), and and select the RAW VRM screen the value in HWINFO POUT actually matches the real value of Pin. See below:
Does the problem happen only when you run both tools at once? It might be a conflict when running both.
Can you please post a side-by-side screenshot of both ASUS and HWiNFO tool showing the VRM section?
