alxns
If BCLK is set lower than the default 100.00MHz, measured BCLK will be really high. As you would expect, that only happens if the readout is bus-clock based.
Unchecking HPET does not have an effect. Enabling spread spectrum does not have an effect besides reading the expected -0.2 MHz value
If BCLK is set higher than 100.00Mhz, the bug does not happen, but readout seems to stay fixed at 100.00 MHz even if I set 100.1250MHz (from the sensors window)
Set at 99.9375 MHz:
100.0625 MHz:
I tested on older HWinfo versions and it happens as well
Apologies if this has been reported before but I did not find anything for this specifically. I have attached the report. DBG file is too big to attach here
Thanks!
Set at 99.9375 MHz:
100.0625 MHz:
Thanks!
